brake upgrade question
Old Apr 16, 2008 | 10:25 PM
thirdgenlover's Avatar
Car: 87 trans am
Engine: 350 TPI bored .040 over
Transmission: modified 700r4
Axle/Gears: stock spline, 3.73 Eaton posi
ok so what is your guys opinion of what the best option to go on when you upgrade your rotors from stock flat surface rotors. cross drilled or slotted. I heard one is actually worse then the other but i cant remember which one? My friends dad just got an 08 corvette and it has cross drilled. Corvette has to live up to their name so they must be good!
Old Apr 17, 2008 | 12:52 PM
WIll36's Avatar
Car: 88IROC, 91Z28 + parts cars
Engine: 355, 408
Axle/Gears: 3.42 LS1, 9" w/ 4.56 and spool
Re: brake upgrade question
It depends either or is better than a stock rotor, but you get what you pay for it you buy cheap drilled or slotted rotors they will crack in fairly short order. That being said slotted rotors wear pads faster because the slot acts like a knife blade scraping along the pad when the brakes are engauged. I have a set of SSBC slotted rotors and matching pads on the front of my IROC and they don't make too much noise, and perform well so I would probably buy another set in the future when these wear out.
Frozer!!!
Jan 19, 2024 04:55 PM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
gta90
Sep 15, 2015 04:00 PM
redmaroz
Aug 16, 2015 11:40 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
