Line locks on pre 87 camaro
Old Jun 10, 2008 | 09:38 PM
wshbrn91's Avatar
Car: 1986 Z28 Camaro
Engine: Rebuilt 82' 305
Axle/Gears: Non-Posi stock =(
Line Locks
Hello,
Im just curious, What EXACTLY do I need to make this work on my 86? What would I have to do?
http://store.summitracing.com/egnsea...115+4294840140
I remember hearing once that something with the lines changed at the end of 86, so you need to do something to make it work?
THANKS!
-Andew
Old Jun 11, 2008 | 09:22 PM
wshbrn91's Avatar
Re: Line locks on pre 87 camaro
Old Jun 11, 2008 | 10:41 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
Read the instructions. http://static.summitracing.com/globa...ions/24048.pdf
Old Jun 12, 2008 | 07:55 AM
wshbrn91's Avatar
If you read my first post, it says:
"Somthing with the lines changed after 86"
So I need some kind of converter parts. I remember seeing a post about it about a month ago, but I searched and search and could not find it.
me
-Andrew
Old Jun 12, 2008 | 10:17 AM
86 406's Avatar
I installed the same kit on my 86 T/A. All the lines and threaded fittings worked great. Very simple bolt on. I didn't need any extra parts.
Old Jun 12, 2008 | 02:09 PM
wshbrn91's Avatar
hmm, interesting.
Well I guess if I decide to get it, ill just get it, and then ill look some more if I run into any issues.
-Andrew
Old Jun 12, 2008 | 02:25 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
What year did these cars go to metric bubble flare connections? If that is what your car has (I would think it does), you'll need to cut and flare your lines, using a metric bubble flare kit, and get a metric (4mm or whatever size it is?) -> 1/8"NPT male, and screw that into the line lock, then the same thing on the other side of the line lock.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
I'llrocya
Feb 2, 2016 11:43 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
Zachattack0925
Aug 12, 2015 09:52 PM
