E brake cable size
Old Jul 1, 2008 | 09:56 PM
Saber's Avatar
Car: 91 camaro RS, 87 T/A
Engine: 350 TBI, 305 TPI
Axle/Gears: 4th Gen 3.42/BW 3.45
E brake cable size
I need to put my ebrake system back together since switching from drums to discs, problem is when i finally found the cables, at pep boys they have 2 different sizes, now these cables have been hard to track down, so i would love to get them asap, problem is they have 2 different sizes listed, both are 14MM and i believe one is like 14.1 and 14.8. Does this make a difference? i have the exact sized on my desk at work, the guy there had no clue and i cant seem to find out anywhere, Would it really matter the size i put on? i just dont want to go ordering the wrong part.
I have a 91. RS with an 87 Formula 9 bolt rear, if that matters.
Old Jul 2, 2008 | 08:30 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Re: E brake cable size
Are you using the stock style iron caliper rear discs on the 9 bolt? If so you'll have issues with the install. There are no bolt in cables that will work with the 1991/1987 combo you are running.
Ed
Frozer!!!
Jan 19, 2024 04:55 PM
Eric-86sc
Apr 3, 2016 03:52 PM
toronto formula
Nov 10, 2015 06:17 AM
kyleb24
Aug 15, 2015 08:24 AM
knight72
Aug 10, 2015 09:32 PM
