bad brakes ???
Old Jul 17, 2008 | 03:43 PM
mrchevy1992's Avatar
bad brakes ???
i have a 1992 camaro rs with a brake problem. i just bought brand new rotors calipers pads drums and shoes. the problem is when iam going down hill i still have a bad vibration in the left front wheel ,its like i never changed anything,its just as bad.a friend of mine said change the brake hoses in the front, is that a likely cause ??? iam stumped and out of cash. please send replies to
mrnascar56@aol.com
Old Jul 18, 2008 | 09:56 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
ROCK & ROLL
Throw a floor jack under the A arm and see if you can
rock the wheel in and out from top and bottom.
You should be able tell if the balljoints or are worn.
Look at the upper strut tower mounts.
Happy Racing!
-If people drove any slower
they’d be going backwards-
Old Jul 19, 2008 | 09:16 PM
mawinc's Avatar
Re: bad brakes ???
Sometimes the two bolts that hold the strut to the knuckle will be loose. I have seen this a few times when people dont tighten them with an impact. check wheel bearings with the wheel on. Check ball joint with jack under crossmember (it has to be in the unloaded position to check) have someone help you check the ball joint so you can watch for movement.
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
dyeager535
Aug 28, 2015 08:10 AM
