PBR Setup. Dose it fit a Drum Brake Rear Quick HELP!!
Old Aug 3, 2008 | 09:00 PM
primerk5's Avatar
Car: 85 Z28 Camaro
Engine: TPI 305
Transmission: 5 spd
Axle/Gears: Uh, Haven't investigated this yet
I have a quick question. I want to pick this up tomarrow before It gets swiped. There is a PBR setup in my local J-yard. I'm wondering if I get the backing plates Rotors and calipers if I'll be able to bolt them onto my Drum brake rear. I have one of the other Disc Brake rears (Steel calipers) Will they fit on that??
I didn't find much on the search function so I'm just trying to get some quick anwsers.
BTW I'm going to get the Proportioning valve as well.
Old Aug 3, 2008 | 09:29 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: PBR Setup. Dose it fit a Drum Brake Rear Quick HELP!!
Won't fit the drum without modification because the axle flanges are different than the disc rear end. The PBR's will fit the disc rear end, though the backing plates must match that rear end (9-bolt for a 9-bolt, 10-bolt for a 10-bolt). Check the following link for the conversion:
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
JamesC
Old Aug 3, 2008 | 09:31 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Not directly, the backing plate mounting is different. It'll fit the disc rear if they're both 10 bolts and you get the backing plates.
Old Aug 4, 2008 | 06:55 AM
primerk5's Avatar
Car: 85 Z28 Camaro
Engine: TPI 305
Transmission: 5 spd
I was wondering on what years came with the PBR setups. Thanks a lot guys I'll be going to get them. I'm almost 99% positive my Disc Brake rear is a 10 bolt and I think I counted 10 on the one in the J-yard as well. I'm going to grab the Calipers, rotors, backing plates, and steel lines. I figure I'll replace the hoses and E-brake cables.
Thanks again for the quick information. I definatly would have never found that thread with my search criteria.
Old Aug 4, 2008 | 04:36 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Ed Miller probably has something that would let you put discs on a drum rear without any fuss.
Old Aug 4, 2008 | 05:44 PM
JamesC's Avatar
89-92. Here' the link that Apeiron may be referring to:
https://www.thirdgen.org/forums/brak...drum-rear.html
JamesC
Old Aug 4, 2008 | 07:17 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Correct, there are plates available to make the swap easy onto a stock drum rear. Any '89-97 rear disc setup will work with them.
Ed
Eric-86sc
Apr 3, 2016 03:52 PM
AkDrifted
Aug 17, 2015 07:45 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
novaderrik
Aug 10, 2015 12:44 PM
