Brakes won't lock up
Old Aug 16, 2008 | 07:33 PM
FFCam1991's Avatar
Car: 91 Formula
Axle/Gears: stock
Hey,
Just recently noticed that under emergency braking situations (deer on the road) that with all my effort the wheels won't lock up. They definately did when I first got the car, and the previous owner said the brakes had just been serviced.
The fluid is all good, so I'm assuming my pads are contaminated with the stuff I used to clean my rims with. I was pretty careless using that, and I know even from mountain bikes that it doesn't take much to contaminate your brakes.
Does this sound correct? This is a scary problem that needs to be fixed right away.
Thanks in advance
Old Aug 17, 2008 | 01:59 PM
89importeater's Avatar
Car: 89 RS camaro
Engine: 454 swap in progress
Transmission: th400
Axle/Gears: 4.11
Re: Brakes won't lock up
use some brake cleaner on the brakes, dont get it on your wheels or paint though. also its not really a good thing for your brakes to lock up.
Old Aug 17, 2008 | 04:27 PM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
If yours brakes lock up you cant control your car.
Old Aug 17, 2008 | 04:47 PM
FFCam1991's Avatar
Car: 91 Formula
Axle/Gears: stock
Right, but its nevertheless rather concerning when you are hitting your brakes as hard as possible and they don't have the power to lock your wheels. They aren't ABS..
Thanks,
Cam
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
zayne0
Aug 24, 2015 07:22 PM
stalkier
Aug 21, 2015 01:54 AM
