Just got my new calipers, did i luck out?
Old Aug 27, 2008 | 04:52 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Ok so i just got my new remanufactured calipers from autozone, i had them shipped to my door for $160 after core charges. When i opened it up i realized they had "PBR" marked on them, correct me if im wrong but PBR are the "preffered" stock brake style offered in the later thirdgens? I have to say im pretty happy with how they look i have to go return the cores now but i noticed the weight difference between my core and the new one.
also can someone tell me why the left and right are designed differently and how do i know which one is which?
please and thank you
im attaching a pic so you guys can tell me if im wrong lol
Old Aug 27, 2008 | 07:42 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Just got my new calipers, did i luck out?
they are the PBR,s however they will not bolt right to your spindles, you need the 1le spindles $$$ or modified stockers. And for 160 you paid for the pbrs. I redid my stock iron ones 4 or 5 years ago and they were something like 40 bux for the pair
Old Aug 27, 2008 | 08:25 PM
AC's Avatar
AC
Car: Used to drive a camaro
The caliper you have in the pic is the driver side rear caliper....no spindles needed. The bracket should be pointing downwards.
Old Aug 27, 2008 | 08:27 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
No, they're the only stock disc brake style offered in later thirdgens.
Old Aug 27, 2008 | 09:00 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The parking brake brackets face the inside of the car. Following is the pass side:
https://www.thirdgen.org/forums/atta...s-89-rline.jpg
Driver's side:
https://www.thirdgen.org/forums/atta...s-89-lline.jpg
JamesC
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
sp8ty
Exterior Parts Wanted
Oct 23, 2015 08:35 AM
HoosierinWA
Oct 7, 2015 10:15 AM
the_hamturdler
Sep 30, 2015 12:50 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
