83 Trans Am rear disc brake setup
Old Aug 28, 2008 | 12:34 PM
CJG1987's Avatar
Car: 1983 Trans Am
Engine: 305 4bbl
Axle/Gears: 10 Bolt 3.27 posi
I have a 83 TA with rear disc setup. the problem is that whe i bought the car the guy i bought it from cut the brake lines for whatever reason. my question is that on the driver's side rear brake, does the brake line go from hard metal line to rubber before the caliper. mine has a metal line that is cut about two inches from where it would bolt into the caliper. i know this doesnt sound right but im explaining it the best i can so bare with me lol.
on the passenger side there is a braket the brake line runs into and comes out the other side as a rubber line instead of metal. is the driver side supposed to do this also? if anyone has a picture of their setup that would be very helpful also
thanks in advance
Old Aug 28, 2008 | 01:25 PM
85IrocZ-28's Avatar
Car: 1985 Iroc Z-28
Re: 83 Trans Am rear disc brake setup
The rear line on the drivers side is metal all the way to the caliper, that is factory. It would be better to install a flex line though. I would do this as you have to create a new section of line.
By the way, he may have cut the line because the rear calipers on the car suck. I just replaced mine with new ones, and the calipers still don't work right. I hate them...and am thinking of upgrading to PBR's. I just need to get the $ together.
Old Aug 28, 2008 | 01:47 PM
CJG1987's Avatar
Car: 1983 Trans Am
Engine: 305 4bbl
how does someone go about fixing the problem? what i mean is that if he cut the line, how do i repair the line so it bolts into the caliper?
Old Aug 28, 2008 | 02:05 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Buy a new line(s). Check the following sites for what you need:
http://www.finelinesinc.com/
http://www.inlinetube.com/
http://www.classictube.com/
JamesC
Old Aug 28, 2008 | 02:13 PM
85IrocZ-28's Avatar
Car: 1985 Iroc Z-28
If you have a location near you that makes brake lines, I would just buy a flare tool and have someone make a section of steel braided line for your drivers side. I would also have a steel braided line made for the passenger side to match.
Old Aug 28, 2008 | 02:20 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
There's a rebuild kit that will fix some of the problems with these discs. Don't know if it's still available. Try:
https://www.thirdgen.org/forums/brak...ght=brake+rear
Old Aug 28, 2008 | 02:57 PM
85IrocZ-28's Avatar
Car: 1985 Iroc Z-28
Yeah, I might try re-building them. I just bought them a couple of months ago, and have had problems from day 1.
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
sailtexas186548
Jan 19, 2016 12:21 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
