Does anyone know what these go to?
Old Sep 12, 2008 | 04:46 PM
srhansen78's Avatar
Car: '92 Z28 25th anniversary/ '89 RS
Engine: 400 sbc
Axle/Gears: moser 12 bolt w/4.10
i bought a camaro and these were some of the parts that came with it. i dont know what type of calipers they are for. Possibly wilwood, brembo, ???. Does any know?
Old Sep 12, 2008 | 07:38 PM
compuwiz1937's Avatar
Car: 2012 Corvette
Engine: LS3
Transmission: TR6060
Re: Does anyone know what these go to?
That could be a bracket for a C5 brake upgrade or something of that sort.
Old Sep 12, 2008 | 08:45 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
They look very similar to the brackets I used for a C5 upgrade. Mine don't have the threaded or allen-head inserts like those, the bolts threaded to the spindle from one side and to the caliper carrier from the other.
Old Sep 16, 2008 | 01:06 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Those are a Wilwood intermediate bracket for a caliper with 5" centered lugs. As to exactly WHAT caliper they fit, can't tell. No part number on them anywhere?
Ed
Old Sep 17, 2008 | 02:29 PM
srhansen78's Avatar
Engine: 400 sbc
thanks to all for your reply. i know they are not for the c5 brake upgrade as i have already done this to my camaro.
ED,
The only number that i can find on them are DP 1253. i have tried doing all kind of searches for this number and othing comes up. Are you sure they are wilwood? i tried doing a search using brembo, wilwood, etc and could not find anything.
Old Sep 18, 2008 | 02:30 AM
ebmiller88's Avatar
Man sometimes I suprise myself, or just get plain lucky.
It is the spindle bracket pictured below, used in Wilwood's kit:
DYNALITE PRO SERIES FRONT HUB KIT
WITH 10.75” DIAMETER VENTED ROTOR
1982 - 1992 CAMARO / FIREBIRD
DISC SPINDLE
PART NUMBER GROUP
140-2992-B
Direct link:
http://www.wilwood.com/BrakeKits/Pages/08/index.asp
The actual P/N is 250-1253R/L, Brackets, Caliper Mounting (pair, one each, left and right)
How's that?
Ed
Old Sep 20, 2008 | 11:22 PM
srhansen78's Avatar
Engine: 400 sbc
THANK YOU very much!!! After you suggested wilwood i started doing more searches using that name and i found the number for the part itself but couldnt find anything with a picture. thanks again.
