Help with rear disc conversion
Old Jan 6, 2009 | 08:59 PM
lnsper's Avatar
Car: 92 RS
Axle/Gears: 3.27 4 wheel disc
I have a 92 RS
I changed the rear end to a 9 bolt BW with disc cast iron calipers for now I plan on upgrading later
After installing the rear end with new reman calipers new ss lines all new hoses I have a soft brake peddle and the rear wheels wont completely stop spinning and the pedal feels soft When I bought the rear end the guy gave me the master cylinder and proportioning valve and said it came off the same car as the rear end I have run about 2 qt of brake fluid threw the system bleeding it and I get no air
There are some # on the pop valve not a good stamping but I think this is what they are NB 35 RH 2457 do these mean any thing they are different then the # on my old pop valve it had MB 34KH 1022
Any help would be great
Thanks Shawn
Old Jan 7, 2009 | 07:01 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Help with rear disc conversion
Did you blench bleed the master?
JamesC
Old Jan 7, 2009 | 09:35 AM
lnsper's Avatar
Car: 92 RS
Yes I tryed that twice
I am going to try a new master from the auto parts store today
Old Jan 7, 2009 | 08:30 PM
lnsper's Avatar
Car: 92 RS
New master and all is good
now that it all works its time to go bigger on the front any suggestions
Old Jan 7, 2009 | 08:41 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
what size wheels are you using?
Old Jan 7, 2009 | 09:07 PM
lnsper's Avatar
Car: 92 RS
I have 18'' s on it so I should have alot of room
Old Jan 7, 2009 | 09:11 PM
JamesC's Avatar
Try Ed Miller's site for big brake upgrades.
JamesC
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Jan 19, 2016 12:21 PM
zayne0
Aug 24, 2015 07:22 PM
