Yet another C5 brake upgrade in progress
Old Jan 21, 2009 | 09:04 PM
ACCLR8N's Avatar
Car: 87 Evoluzione, 84 TransAm, 05 GTO
Engine: LT1, L98, LS2
Transmission: (2) T56 & (1) 700R4
Axle/Gears: Moser 12-bolt w/3.73 & Stock
Just wanted to thank all the ThirdGen board members, especially Ed Miller for figuring this out and inspiring my low buck brake upgrade.
Attached Thumbnails Yet another C5 brake upgrade in progress-rotor_notch.jpg   Yet another C5 brake upgrade in progress-mod_spindle.jpg   Yet another C5 brake upgrade in progress-caliper_bracket.jpg
Old Jan 21, 2009 | 10:30 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Re: Yet another C5 brake upgrade in progress
I'm sure you'll enjoy them. I can't take credit for the C5 stuff, there's many others to thank before you get to me. I just took the ball and ran with it. I'm still running so to speak, in many different directions.
Good luck!
Ed
Old Jan 29, 2009 | 05:56 PM
ACCLR8N's Avatar
After that effort, had to shoot some paint on it. No calipers yet, but the rotor appears to be centered in the caliper bracket with about the same gap radially to the outer diameter.
Attached Thumbnails Yet another C5 brake upgrade in progress-hub_bracket.jpg   Yet another C5 brake upgrade in progress-rotor.jpg
Old Feb 12, 2009 | 12:06 PM
Tice's Avatar
Car: 1991 Formula Firebird
Engine: Pontiac 355 stroker (305 TBI 4Sale)
Transmission: Pending Manual , 700r4 for sale...
Axle/Gears: Stock... for now
So What all has to be done to Convert from Drum to Disc in rear? Just get the Plates, Backing plates, Rotor and Calipers, and put the screws where they go, and the Lines where they go? Sorry if i'm mistaken...
Old Feb 12, 2009 | 07:07 PM
ACCLR8N's Avatar
If you don't need an e-brake, C5 could be that simple. I cheated and ordered a 4th Gen spec Moser 12-bolt and swapped in the LT1 rear brakes from my donor car. The LS1 rear disc conversion requires a little cutting and drilling to the drum flange. Doesn't look too hard at all. Hand tools.
https://www.thirdgen.org/ls1reardisc
Old Mar 9, 2009 | 07:45 AM
383fbod's Avatar
Car: 88 IROC-Z
Engine: 383
Axle/Gears: 4th gen 3.42posi
dose anyone make a C5 spindle/hubs to backspace Z06 rims properly without spacers?
currently I have 2.1/4" SPD adapters and im worried about strength with my C5 upgrade.
Old Mar 9, 2009 | 11:33 AM
ACCLR8N's Avatar
I've not seen that in my research. On the plus side you will need smaller spacers with normal converted thirdgen hubs.
Old Mar 9, 2009 | 03:18 PM
383fbod's Avatar
Car: 88 IROC-Z
Engine: 383
just as i thought
ever heard of spacers braking or extra weel stud forces,etc.?
i dont want an inferior spacer to be the reason i wreck(or any thing for that matter)
Old Mar 10, 2009 | 11:42 AM
ACCLR8N's Avatar
Though none of them are DOT approved, I have never heard of one breaking. I'm running a spidertrax set on my Jeep along with a lot of other people. These see quite a bit of abuse and the failure has always been something else.
Old Mar 10, 2009 | 08:04 PM
383fbod's Avatar
Car: 88 IROC-Z
Engine: 383
o
Old Mar 10, 2009 | 08:05 PM
383fbod's Avatar
Car: 88 IROC-Z
Engine: 383
o so they cant be used on the street "legally"
Old Mar 11, 2009 | 12:25 PM
Tice's Avatar
I really need to look at those articles more often, thanks bro.
angel2794
Sep 8, 2015 06:22 PM
SG91camaro
Sep 5, 2015 10:27 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
