question
Old Feb 25, 2009 | 08:43 PM
louflemm's Avatar
question
what rear came in the 1986 trans ams (disk brakes)? if it says performance suspension on passenger side does this mean ws6? this car is an LB9 auto 700r4 thanks guys
Old Feb 25, 2009 | 10:03 PM
Guest
Guest
Posts: n/a
Re: question
rowr HISSSSSSSSSS
Anyway, best way to know is look. Count the number of bolts on the cover. Its most likely a 9 bolt borg warner rear. 2.77 was the std ratio, 3.27 was optional. If it has rear discs, it had to have WS6 as well so as long as the rear was not swapped in at a later time you know for sure. You could also measure the sway bars, 36mm front 24mm rear.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
