S-BLAZER REAR DISC ?
Old Mar 16, 2009 | 04:05 PM
TIRESSMOKE's Avatar
Will rear disc setup from s-10 blazer fit 85 rear I have complete rear from blazer didnt cost me anything just wondering if anyone else has done this swap? the backing plate flanges appear to be the same but I havent gotten under the car to measure anything yet ! car is currently equipped with drums
Old Mar 17, 2009 | 03:15 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: S-BLAZER REAR DISC ?
I would think so, since the s-trucks got the 10 bolt rear end also. However, an 85 model will probably have the same iron calipers which came on our cars from 82 to 88. If so, it might not even be worth the trouble. I have them on my car, and they don't really work all that well.
Old Mar 17, 2009 | 04:03 PM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
are you talkin the rear end or just the brakes? also will zr2 brakes/rear end work? i know my zr2 has a different rear end then normal dimes do. not planning on swapping the rear end in my car and truck, just outta curiosity if i end up with some spare parts
Old Mar 17, 2009 | 04:56 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Yeah, I meant the brakes, not the whole rear. Although it's pretty much the same rear and, it's set up for leaf springs, which means no torque arm mount, no coil spring perches, no panhard rod mount, and the track width is probably different. I'd bet though that the brakes can be used.
Old Mar 17, 2009 | 06:03 PM
Brennan's Avatar
weird that never crossed my mind
Old Mar 18, 2009 | 01:19 AM
crytical point's Avatar
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
They should fit the axle but I don't know about spacing.
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Jan 19, 2016 12:21 PM
zayne0
Aug 24, 2015 07:22 PM
