12" LS1 brakes under 15" wheels
Old Apr 13, 2009 | 12:36 AM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
I have my spindles cut, brackets made and everything cleaned & painted up for the LS1 brake swap and everything fits fine with about 1/2" of clearance with 1.5" wheelspacers. I could stick corvette calpers on here if I wanted to and still have 1/4" of clearance. I'll have to do a little trimming to the fenders to get things to clear with the wider track. Everything's ready to put on, now I just want to see what other people's solution for the bump stop has been. My idea is to make a small bracket that attaches to the lower adapter bracket bolt from the backside (you can see it sticking out in the pictures) that lines up with the stock bumpstop location.
Attached Thumbnails 12" LS1 brakes under 15" wheels-sany0241.jpg   12" LS1 brakes under 15" wheels-sany0243.jpg   12" LS1 brakes under 15" wheels-sany0245.jpg
Old Apr 13, 2009 | 12:59 AM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Re: 12" LS1 brakes under 15" wheels
nice
Old Apr 13, 2009 | 12:54 PM
arrowcamaro's Avatar
Car: '88 GTA
Engine: L-98
Are you referring to the "steering stop"?
Old Apr 13, 2009 | 11:30 PM
bl85c's Avatar
Car: '85 maro
Yep, steering stop. Turns out I don't need a bracket anyway, the bolt lines up perfectly with the stop. All I need to do now is grind it down ~1/2".
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
sailtexas186548
Jan 19, 2016 12:21 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
