Adjustable Proportioning Valve
Old Apr 26, 2009 | 10:24 AM
tri power's Avatar
I was just wondering if anyone has replaced their stock 4 wheel disc brake proportioning valve with a adjustable proportioning valve cant find stock valve for my car.
Old Apr 26, 2009 | 03:24 PM
MurcoRS's Avatar
Car: 1989 Camaro RS
Engine: ZZ4 350
Axle/Gears: BW 9-bolt w/3.73
Re: Adjustable Proportioning Valve
What year is your car, which rear brakes do you have?
Old Apr 28, 2009 | 04:55 PM
tri power's Avatar
85 Transam I put disc brake rear out of 86 Iroc 10 bolt.
Old Apr 28, 2009 | 09:30 PM
tri power's Avatar
Mine has 5 lines 3 on top 1 on side 1 on bottom
Old Apr 28, 2009 | 09:45 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Humm, that looks like what I've always thought was the 82-83 valve, which is SAE. Interesting. Certainly doesn't resemble the one in my 85.
JamesC
Old Apr 29, 2009 | 09:01 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
I'm in the middle of that right now, on the 90 formula.
The biggest obstacle I had to overcome, is that the original
lines/fittings are all "bubble" flare, but the only fittings I can
find available are "inverted" flare. Reader's Digest version is
that I get some short bubble flare lines, and convert one end
to standard inverted flare. (Parts houses that loan/rent tools
will usually have the inverted flaring tool.) I'm removing the
prop valve entirely, using a tee fitting for the front, and adj.
unit (from SSBC) for the rear. I'm pretty **** about stuff like
this, so I'm also fabbing a new mount for both units. Will post
some pictures, & more details when I'm finished. If you have
some more detailed questions, I'll help out as best I can.
Old May 2, 2009 | 09:01 PM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
I did the adjustable valve and let me tell you its probably one of the best mods for these cars to be able to dial in the brakes to your driving preferences. its a royal pain in the butt to do the flairing and such but its well worth the gains in the end. I didnt even bother looking for a stock disk/disk prop valve. Here is the article i used as a reference for doing the swap. I followed it to the T and everything turned out great. I didnt use a willwood though...SSBC prop valve.
https://www.thirdgen.org/propvalve
Hotrodboba400
Dec 10, 2019 07:07 PM
J-money
Jan 4, 2019 09:45 AM
dimented24x7
Sep 6, 2015 03:51 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
