Front discs
Old Jun 5, 2009 | 02:45 PM
Devryn's Avatar
Front discs
Are the front disc brakes from a 99 t/a better than the front discs on a 88 Firebird? If so, what are the major differences, and can you easily upgrade the 88 to 99 hardware?
Old Jun 6, 2009 | 08:17 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Front discs
yes they are better, no they will not bolt on. It is a common swap though, requires modified spindles, brackets, hubs ect. A search will turn up the info, or edmiller sells the kits, this is his site
http://www.flynbye.com/index.html
Old Jun 6, 2009 | 09:35 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
Re: Front discs
Your brakes are 10.5" rotors and single piston calipers, while the '99 has 12" rotors and dual piston calipers. Other difference being the '99 rotors are slip ons rather than hub and rotor assemblies. Made a huge difference with my car, I'd suggest the swap to any and all!!
Old Jun 9, 2009 | 08:53 AM
Devryn's Avatar
Re: Front discs
So, the way I read that website, if I send them my spindles, they'll convert them for the LS1 F-bodies disc brakes for $75?
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Jan 19, 2016 12:21 PM
zayne0
Aug 24, 2015 07:22 PM
overdriv
Aug 20, 2015 03:52 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
