Brake genuis' unite. i got a quick ?
Old Jun 9, 2009 | 10:01 PM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
ok, so my actuator screw may be stripped. where do i find a new one. i tried searching, and looked everywhere. i just got my 18019028 gm# caliper rebuild kit, no actuator screw though plze help.! again i need the actuator screw. and i have a steel line to the rear driver side caliper. i mean its solid with ribs on it. do i need to replace it??i know that the passenger rear caliper has a rubber braker line. im doing a complete overhaul on the brakes. should last another 25 years
Old Jun 10, 2009 | 06:39 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Brake genuis unite. i got a quick ?
OE lines. No need to replace unless they've gone bad.
JamesC
Old Jun 10, 2009 | 01:20 PM
is it bad to use Teflon on the bleeder screws? last time they didnt seal that well, i used a little Teflon, that was two years ago though.
Old Jun 22, 2009 | 11:41 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I don't think it's bad per se, but they shouldn't need it. If the bleeder won't seal on its seat, then the caliper or the bleeder is bad.
Ed
Old Jun 23, 2009 | 12:04 AM
youre pretty smart. im going to get new bleeder screws, calipers are good. the only thing thats holding me back is the aircompressor to blow out the pistons, im going to pickup a tank tomorrow. but um, it is cool to use gas rated teflon tape right?
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
happyhapka
Aug 15, 2015 04:42 PM
