LS1 to C5 fronts
Old Jul 14, 2009 | 01:12 PM
BCdawg57's Avatar
Car: '91 Z28, '13 Civic EX-L
Engine: 355 LT1, 1.8 I4
Transmission: T56, 5spd auto
Axle/Gears: 10 bolt 3.42(as long as no breaky)
LS1 to C5 fronts
Just a quick question guys.
Would it be possible to use the 13" front rotor from a C5 on the LS1 set up by just changing the caliper mounting bracket?
Would the LS1 caliper work?
Jakob
Old Jul 14, 2009 | 03:41 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
Re: LS1 to C5 fronts
You can use a C5 caliper on the LS1 abutment bracket (caliper carrier) and LS1 12" rotor. To use the C5 13" rotor you will have to switch to the C5 spindle bracket and abutment bracket (caliper carrier).
Old Jul 14, 2009 | 04:40 PM
Blownz28man's Avatar
Car: 92 25th anv z28
Engine: 346 TC78 Turbo
Transmission: 4L80E
Axle/Gears: 3.25 9"Nodular, Strange axles
I'll trade ya... I have c5 brakes and want to be able to run some skinnies in the front. Everything is new has like 100 mi on it. send me a pm
Old Jul 14, 2009 | 08:14 PM
Firebat's Avatar
GTO 17x4.5 spares will clear C5 brakes. Have to have spacer adapters though, just like 4th gen rims.
Old Jul 15, 2009 | 06:58 AM
BCdawg57's Avatar
Thanks for the replies, though it's not what I wanted to hear. Blownz28 I sent you a pm.
Old Jul 15, 2009 | 09:50 AM
BMR Sales's Avatar
Former Sponsor
We offer an adaptor bracket for putting the c5 setup on the ls1.
Old Jul 15, 2009 | 10:56 AM
BCdawg57's Avatar
Sweet. With these I would just have to get the c5 caliper bracket and rotor correct? I can use the ls1 caliper correct?
Old Jul 15, 2009 | 04:15 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
The BMR brackets are to convert a fourth gen 93-02 to C5 brakes. These brackets will not work on a thirdgen.
Old Jul 15, 2009 | 04:26 PM
BCdawg57's Avatar
Why not? What's different between a 4th gen and the 4th gen brakes on a 3rd gen that would inhibit the use if these brackets?
Old Jul 15, 2009 | 06:16 PM
arrowcamaro's Avatar
Car: '88 GTA
Engine: L-98
Correct. Totally different, wont work. Not even close.
Old Jul 15, 2009 | 06:37 PM
Car: '88 GTA
Engine: L-98
Look: 4th gen left, 3rd on the right
Attached Thumbnails LS1 to C5 fronts-img_0205.jpg   LS1 to C5 fronts-after.jpg
Old Jul 15, 2009 | 10:13 PM
BCdawg57's Avatar
got ya. didnt realize they were so different.
Old Jul 15, 2009 | 11:30 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
I know the c5's are bigger diameter but also put the rotor outward probably 1/8"-1/4". I don't think anyone makes the spindle bracket, but one could be made to use your caliper and bracket on the c5 rotors. I almost did this, but my choice to use the 15" Z28 wheels wouldn't allow the 13" rotors.
Old Jul 21, 2009 | 09:19 PM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
LOL BMR seems to be confused. Maybe you should ask your boss to use the computer next time. lol
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
loud91rs
Oct 5, 2015 10:05 PM
