where is the brake bleeder on rear?
Old Jul 30, 2009 | 04:26 PM
redfivexw's Avatar
sorry for stupid question, but where is the brake bleeder on my 91 firebird with drum rear brakes? I have bled brakes before, but usually they are obvious. Is the bleeder the valve at the top of the rear axle, on the brake back? It has a rubber white cap on it? It is hard to get to and a bit rusty, i want to make sure i am turning the right thing! any advise is appreciated, i changed a rear line and now i have spongy brakes.
Old Jul 30, 2009 | 04:31 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: where is the brake bleeder on rear?
it sounds like you are looking at the right thing. Its on the backing plate towards the top and it sits recessed in the backing plate. A long 1/4" drive socket of the appropriate size work really well. Sorry i dont remember exactly what size it is of the top of my head.
Old Jul 30, 2009 | 10:58 PM
shermanwizard's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Bleeder is directly above the inlet line to the wheel cylinder. A 5/16 or 8mm socket should fit. Try using a 6 point socket since the 12 point socket may round off the corners especially if the bleeder screw is rusted.
Old Jul 31, 2009 | 05:48 AM
redfivexw's Avatar
thanks for the help, 8mm 1/4" socket did the trick. Took 5 minutes to bleed the brakes.
Vintageracer
Jan 10, 2020 05:33 PM
Eric-86sc
Apr 3, 2016 03:52 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
kyleb24
Aug 15, 2015 08:24 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
