not grabbing at all
Old Aug 18, 2009 | 11:55 PM
91_GTA305's Avatar
Car: 1991 Trans Am
Engine: sb chevy's.
not grabbing at all
so i noticed my driver side front brake would squeak a little so i pulled the wheel off and took off the brake pads to see what they looked like. they were still good. well when i was trying to put the caliber back on i noticed i was gonna have to sqeeze the piston back in some just to get it on the rotor. so i got it in a bit just enough to where it fit good. when i dropped the car and took it for a spin i realized i only had the front passenger brake working. so i pulled the wheel off and it still wasnt closing no matter what i tried doing. any suggestions?
Old Aug 19, 2009 | 01:02 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: not grabbing at all
It's kind of hard to decipher that.... but from what I gather one of your front calipers isnt grabbing. If thats the case you should be able to feel the car snatching to the side when you brake.
Get a new brake line and caliper for that side and replace em. The line will cost more than the caliper.
Old Aug 22, 2009 | 10:29 AM
Happy Fun Me's Avatar
Engine: T.P.I. 350
Transmission: 700r4 Auto
If i'm understanding you right, you didn't have this problem to begin with. Just some squeeks. If that's the case you should double check your work. Take it all back apart and make sure everything back together right, no kinked lines or anything. Compare with the other side if you need to. I wouldn't just start buyin parts until you've double checked your work.
usafirebird
Exterior Parts for Sale
Oct 19, 2017 02:00 PM
mfp189
Sep 27, 2015 09:25 AM
Mongoose462ci
Sep 16, 2015 11:46 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
