Need help finding parts
Old Sep 10, 2009 | 10:59 AM
RazorN8's Avatar
Car: 1987 camaro
Engine: 383 AFR heads
Axle/Gears: Ford 9" 3.70:1
I just switched to a borg warner rear end with disc brakes from drum brakes. The rear is out of a pre-88 car. It came with everything for the brakes except one of the brackets that bolts to the caliper and holds the e-brake lever return spring. I have called every junkyard that I can find and even posted on junk yard dog. Nobody knows what I'm talking about or wants to deal with such a small order. I found a caliper on e-bay that has the bracket, but it costs $140 or some crazy nonsense. Can any of you guys suggest where to find this bracket? I assume I need it because everywhere I read, it says I must use the e-brake at all times or the caliper will seize.
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
firebirdchick28
Mid-West Region
Aug 16, 2015 02:52 PM
1nastygta
Aug 8, 2015 07:38 PM
guy76767
Aug 6, 2015 05:58 PM
