LS1 Brake Upgrade Questions...
Old Sep 19, 2009 | 03:27 PM
WhiteysTA's Avatar
Car: 87 Chevy Camaro Iroc-Z
Engine: 350 LT1
Axle/Gears: 3.27 9-Bolt w/TA Perf. Stud Gurdle
Hello, I've looked at every how-to site I could find about the LS1 brake upgrade, and are still left with a few questions I could not find answers to. First, what is a part number for the longer wheel studs, or at least the size/thread I would need to look for. Also, what is the correct thickness of the adapter bracket, I've found one site saying 3/8" and another saying 1/2". Does it make a difference at all? Thanks to anyone who can help!
Old Sep 19, 2009 | 09:15 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Re: LS1 Brake Upgrade Questions...
Wheel studs are a Dorman/Motormite overlength stud with standard M12x 1.5 thread, Napa will have them. Bracket thickness will vary depending on spindles, I used a 5/16" bracket. 1/2" is way too thick to use in LS1 applications.
Ed
Old Sep 22, 2009 | 08:54 AM
WhiteysTA's Avatar
Engine: 350 LT1
Just curious, will the ARP studs work in this situation? I found a set on summit, but they are 2.5" long. Is that too long, or is there another part number for them in a smaller size. Thanks again!
Frozer!!!
Jan 19, 2024 04:55 PM
deracer
Apr 11, 2016 12:04 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
zayne0
Aug 24, 2015 07:22 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
