Knocking when braking ?
Old Sep 21, 2009 | 03:46 PM
gta_knight's Avatar
Car: 1987 GTA
Engine: 350 TPI w/ extras !
Hey guys,
This knock has been there for a bit, over the last week i have replaced the brake discs and pads, that didnt help but i wasnt expecting it too they just needed done anyway.
What i thought it could be was the balljoint after inspection, i jacked the car up and there was loads of movement so i thought maybe it was rattling around under braking, so ive just had them replaced, but when i took the car out and stepped on the brake....KNOCK KNOCK KNOCK KNOCK.
Ive checked all the steerings/suspension bits and just about everything else under the car and nothing seems to be loose.
If i brake lightly, the knock is fairly quiet, but if i slam the brakes on the knocking is very loud and you can feel the car shaking about when coming to a stop. definitly sounds like its coming from the front.
A friend of mine suggested it might actually be air in the system and i should bleed my brakes, i would have never of thought of that ?
Old Sep 25, 2009 | 07:00 AM
always tinkerin's Avatar
Car: 85 Berlinetta
Engine: 408 SBC with a S-480 Turbo
Transmission: TH350/Hughes converter (Thank Pete)
Axle/Gears: 3:23 28.5" tire
Re: Knocking when braking ?
Remove and inspect front wheel bearings.
Check to see if new brake pads fit loosely on calipers...even 1/4" rotational movement of the pad on calipers will make knocking noise when stopping. (ran into this last week-Autozone gold pads)
Old Oct 1, 2009 | 01:43 PM
gta_knight's Avatar
Car: 1987 GTA
well do i feel stupid, i was convinced it was coming from the front and the other day i thought id test something, so i pulled the handbrake up a bit while going down the road and...KNOCK KNOCK KNOCK...
so i got the drums off and there was a fair bit of crap in both sides, so i blasted it out with the air gun, however my right hand side drum has a big groove scorn into it which corresponds onto the shoes. Both sides need new shoes looking at them, so i think i'll get new shoes, drums and pistons and get it all sorted out
dbrochard
Sep 19, 2015 08:13 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
tgp1990
Sep 4, 2015 06:24 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
