Rear Disc
Old Oct 25, 2009 | 04:52 AM
AllStockCamaro's Avatar
Car: 1991 Camaro Z28 Convertible
Engine: 305 TPI (Stock)
Transmission: 700R4 (Stock)
Axle/Gears: 2.73 Gears (Stock)
Rear Disc
Hi
I have a 1991 Z28 Convertible, its got drums out back. I was wondering will stock rear disc brakes bolt in, if not what is necessary to install them or would it be easier to bolt in a disc rear end?
In front its all stock should I upgrade to better rotor and pads, (if so please recomend a setup) or should I go for 1LE brakes.
I dont race or take it to the track, I just want to know I can STOP if I need to.
Old Oct 25, 2009 | 07:04 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Rear Disc
The following FAQ will provide pertinent info:
https://www.thirdgen.org/forums/tran...-10-bolts.html
I have the 1LE set-up all the way around:
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
JamesC
Old Oct 26, 2009 | 01:44 AM
Re: Rear Disc
I might do the 1LE steup as well.
Thanks and God Bless.
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Jan 19, 2016 12:21 PM
zayne0
Aug 24, 2015 07:22 PM
