spindle nut size
Old Nov 5, 2009 | 09:28 AM
charlietransam's Avatar
Car: 1984 Trans am
Engine: V8
spindle nut size
i want to chage my front calipers and rotors but before i start i wanted to know what size spindle nut is on the car. its an 84 trans am. plus i also wanted to know if i can use regular sockets to take it off or do i have to buy a spinlde nut socket? and what size sockets do i need?
Old Nov 5, 2009 | 10:28 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: spindle nut size
The nut should only be about hand tight, so even a pair of channel locks should do the trick.
JamesC
Old Nov 5, 2009 | 10:29 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
24mm for the spindle nut, 3/8" hex for the caliper bolts. For the work you described this is all you need. I'd change out the brake hoses while you're at it.
Ed
Nervous2
Oct 8, 2015 10:53 PM
jdperformance
Sep 16, 2015 11:55 AM
rb85TA
26
Sep 14, 2015 10:29 PM
Fox118
Sep 12, 2015 09:29 PM
m00n420
Sep 11, 2015 02:39 PM
