brake master cylinder Q
Car: 91 Camaro RS
Engine: 3.1 liter
Axle/Gears: positrac off an 83 T/A
Why do the brake master cylinders run from either 82-83,82-88, 0r 90-92. (the latter of which is hard to find) My situation is that I swapped an 83 posi rear end with disc brakes making it 4 wheel disc. brakes were fine till recently. never changed the proportioning valve. i decided it was time to swap in the correct one. Plus the BMC needs replaced due to a leak. Does anyone think it would be a problem if I put a BMC for an 83 on there? I need to know if there would be a problem because I'm having brake issues and I wanna find out how to fix it before my car ends up plastered to the back of another one.
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: brake master cylinder Q
you should use the master cylinder for the 4 wheel disc. the piston is smaller. they are inexpensive from autozone.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
GM says the master doesn't have to be changed:
https://www.thirdgen.org/forums/susp...fferences.html
82-83 cars are SAE. 84-88 are metric. IIRC, the thread pitch changed sometime in 89+.
For best brake performance, I'd certainly change the proportioning valve (valves were designed to optimize specific systems: drum or disc).
JamesC
JamesC
dbrochard
Oct 3, 2015 12:43 PM
