Need help with brake size!!!
Old Jan 17, 2010 | 12:02 AM
bowtiejoe's Avatar
Car: 68 CAMARO, 05 VETTE, 90 IROC
Engine: 327,LS2,305TPI
Transmission: TH400,STOCK,5 SPEED
Axle/Gears: 373,STOCK,342
I got a 1990 Iroc Z, LB9,MM5,G92,J65. I bought cross drilled rotors over the internet and specified my exact car but recieved 1LE rotors and pads. My question is, are the stock rotors on the front of my car 10.5"? and the rear rotors that came in also look slightly bigger, did 1Le's also have bigger rear discs? The ones they sent me are fronts 11 55/64" and rears 11.5". What size do I need for the front and rear without modification???
Old Jan 17, 2010 | 12:27 AM
bowtiejoe's Avatar
Re: Need help with brake size!!!
Anyone?
Old Jan 17, 2010 | 06:43 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Below.
JamesC
Old Jan 17, 2010 | 06:45 AM
JamesC's Avatar
Fronts are single-piston Delco-Moraine iron calipers with 10.5" rotors (82-92 unless the car was truly a 1LE). The rears, 82-88, are the same as the above; however, 89+ rear disc cars have single-piston PBR alum calipers and 11.7" (or so) rotors. This latter is the so-called 1LE, but all J65 cars in that timeframe were equipped with them.
JamesC
toronto formula
Nov 10, 2015 06:17 AM
kyleb24
Aug 15, 2015 08:24 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
knight72
Aug 10, 2015 09:32 PM
