SSBC - Anyone Use Them?
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
Guys my front brake pads are almost to the point of grinding into the rotors (Although the rotors are shot too so I'm not concerned), and I was looking for a good replacement set. I have been looking at a pair of powerslot slotted rotors and a set of Hawk HPS pads. But I was also looking at the Stainless Steel brakes short stop kit:
http://www.spohn.net/shop/1982-1992-...s-Package.html
How do these compair with the powerslot/hawk combo and what would be the advantage of choosing that vs the SS brakes package?
Car: 1991 Firebird
Engine: 3.1L +bolt ons
Axle/Gears: Moser forged, 3.73, SLP posi
Re: SSBC - Anyone Use Them?
It's $30 cheaper at Year One. Part number BK82.
I've got the SSBC kit. I like it. Dramatic difference vs stock. But, when the pads wear out I will be replacing them with the Hawk pads. I have powerslot rotors and HPS pads on my N-body daily driver and they are way better than stock. I can't compare the 2 directly as they are very different vehicles, but either way seems to be a cheap effective upgrade.
Car: 89 Formula TPI
Engine: LB9
Transmission: WC T5
Axle/Gears: 3.73 posi locker ls1 discs
Thats the brake kit I'm gonna get after I get my lsx/t56 swap done, I wanna get the big brake kit for my car. The seem good I had ssbc slotted rotors on my 01 on all four corners and they worked great.
Car: 88IROC, 91Z28 + parts cars
Engine: 355, 408
Axle/Gears: 3.42 LS1, 9" w/ 4.56 and spool
I ran that for about 2 summers. Worked very well, no more fad like stock. Summit also sells it cheaper.
Car: 1989 RS Camaro
Engine: 305 TBI
Transmission: 700-R4 with Overdrive
Hey CamaroPerformers did an article on the SSBC Quick Change caliper kit. No numbers are given, which sucks, but the installation is outlined. Hope this helps!
http://www.camaroperformers.com/cama...rade/ssbc.html
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
bigblak
Aug 23, 2011 09:34 PM
