Performance Brakes
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
Performance Brakes
what do you guys recommend for performance brakes, pads and rotors?
Re: Performance Brakes
is Baer or brembo good?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Nothing wrong with any of the aftermarket performance brake systems. What kind of budget do you have? What kind of performance are you looking for?
Good street brakes are different from drag brakes which are different than high performance road race/autocross type brakes. You can easily purchase a brake system that far exceeds what you need on the car.
a good street/road race that would fit inside a 15 inch rim.
Car: check
Engine: check
Transmission: check
Car: 84 TA,69 camaro,81 vet 92 vet
Engine: 400
Axle/Gears: 3:73
I went the c5 way. Really not too bad of a job. The first wheel is the learning experience, from there it is esay.
