no rear brakes
Old Feb 14, 2010 | 11:23 AM
yevgenievich's Avatar
Car: numerous
Engine: ls1, others
Transmission: t56, others
Axle/Gears: 3.23 7.6"
no rear brakes
i have a problem i am trying to solve. Originally i had a drum rear end and the rear brakes never really worked. With the rear end up in the air and in drive pressing the brakes as hard as i could the rear wheels would still slowly spin. Forward about a year and i swapped to disk brakes in the back with new rotors and pads. They work but similar to the drum brakes i had and barely hold the rear wheels in place when in drive. I am thinking that i might need a new proportioning valve but not sure which one to get or if that would help my problem or not.
Old Feb 16, 2010 | 09:04 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: no rear brakes
mine did the same when i changed to disk rear. have you replaced the rubber flex line? they can rot inside and cause a blockage.
Old Feb 17, 2010 | 06:46 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: no rear brakes
Info on the correct combination valve is toward the bottom of the following FAQ:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Vintageracer
Jan 10, 2020 05:33 PM
Eric-86sc
Apr 3, 2016 03:52 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
kyleb24
Aug 15, 2015 08:24 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
