Correct Stock Rotors? 1992 Z28 (G92)
Old Feb 27, 2010 | 07:33 PM
JeffG3209's Avatar
Car: 1992 Z28 Coupe
Engine: LB9
I have a 1992 Z28 (G92). Does anyone know for sure if the G92 package in 1992 had "1LE" brake rotors. I am pretty sure they did but the "auto parts store" has me all confused.
If I do need 1LE rotors, has anyone bought from this seller
Old Feb 27, 2010 | 07:39 PM
ls six's Avatar
Re: Correct Stock Rotors? 1992 Z28 (G92)
Look at your brakes, if the fronts have 2 pistons and are aluminum then they are 1LE, if not then they are standard.
Old Feb 27, 2010 | 07:43 PM
JeffG3209's Avatar
Car: 1992 Z28 Coupe
Engine: LB9
Thanks for the quick response!
Old Feb 28, 2010 | 06:39 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
If your 92 has rear discs, it'll have the so-called 1LE brakes (single-piston alum calipers with 11.7" rotors), even though all 89-92 J65 cars were equipped with them. My "guess" is that you have the standard Delco-Moraine calipers up front (single-piston iron calipers with 10.5" rotors). If you'd like to see pics of the front and rear 1LE set-up, check my Car Details below.
JamesC
Old Mar 7, 2010 | 09:23 PM
JeffG3209's Avatar
Car: 1992 Z28 Coupe
Engine: LB9
Rotors:
The Rears are 11.5ish"
The Fronts are 10.5"
Both front and rear are single caliper....
What does this mean?
1LE or Standard Rotors?
Old Mar 8, 2010 | 12:20 AM
Guest
Guest
Posts: n/a
I wouldnt call any of that 1LE. Really the difference in the 1LE is larger front rotors. So you have the normal, 'standard' rotors. As does most everyone else who owns one of these cars and still have stock brakes.
Old Mar 8, 2010 | 06:33 AM
JamesC's Avatar
Originally Posted by JeffGordon
Rotors:
As I suggest in post #4 and as Mad mentions, you have the standard set-up for four-wheel disc brakes, 89-92.
JamesC
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
