One-way check valve???
Old Mar 26, 2010 | 03:23 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
What is the little cannister thing that goes between the booster & the vaccum source called?
What purpose does it serve?
Do I need to put one on since it was removed by the PO?
Front disc, rear drum.
Weather is improving & will be test driving the ol' Camaro in a couple days!!
Thanks for any help // tips!!......
Old Mar 26, 2010 | 05:08 PM
Pocket's Avatar
Car: 91 Trans Am
Re: One-way check valve???
It was a TBI thing. V6/TPI and later engines dont use one
Old Mar 26, 2010 | 06:41 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
carb motors have it too. its a filter to keep gas fumes out of the booster that can degrade the rubber bladders inside the booster. Port injection systems dont have fuel running in the manifold for any real period of time, so they dont need them like the carb/tbi systems do
Old Mar 26, 2010 | 10:15 PM
Car: '87 Camaro
Thanks for the replies--
I will be puting 1 in 2morrow!! It came in one of the (many) boxes of parts.
deracer
Apr 11, 2016 12:04 AM
backtothe80s
Sep 5, 2015 12:39 AM
mike_c
Aug 27, 2015 04:32 PM
Out-Cast
Aug 17, 2015 10:57 AM
