Yes, Another E-brake question
Old Apr 2, 2010 | 11:03 PM
Dr.NickRiviera's Avatar
Car: 1987 Trans Am
Engine: tree-fiddy
OK, my 87's e-brake doesn't work. If I try to pull up the handle I'm lucky to get 2 clicks. Then it is stiff as heck and with all my might I might get one more click in, but it is no where near enough to engage the brake.
I did the put 175lbs of force on the brake pedal and adjust the lever and was able to get it to 7 clicks, but still not enough to engage the e-brake.
After a few attempts the lever is back to 2-3 clicks and done.
This is a disk rear. Any hints, tips?
Old Apr 2, 2010 | 11:07 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: Yes, Another E-brake question
is the cable seized? i would disconnect the cable and see if it moves freely. does this have ebrakes built in to the calipers? could be a problem in the calipers
Old Apr 2, 2010 | 11:34 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
I agree with skirkland. Disconect the cable at the calipers first. If it is still hard to move then disconect them in the trans tunnel. This will help you isolate what section is actually bad. If your under the car, can you see any part of the cable that has been smashed or burnt by the exhaust?
Old Apr 9, 2010 | 03:53 PM
Car: 1987 Trans Am
Engine: tree-fiddy
OK, well I've narrowed it down to the pass side being the culprit making the e-brke handle not go up. With just the drivers side connected I have to crank the handle ALL the way up even with the adjuster screw set.
I might just rebuild the rear calipers and re run the bake cables.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
