Brake parts
Car: 1989 Pontiac Firebird Formula 350
Brake parts
I am looking to replace all brake parts on my car and here is what I have listed to get. These are from Advanced Auto Parts
Brake Rotors
Wearever Brake Rotor - Front
Part No. YH141233
29.99
Wearever Brake Rotor - Rear
Part No. YH141473
33.99
Brake Pads
Wearever Gold Brake Pads - Rear
Part No. GMKD 154
37.99
Wearever Ceramic Brake Pads - Front
Part No. CNAD 154
39.99
Brake Booster and MC
Cardone Power Brake Booster
Part No. 50-1250
156.29
Rear Calipers
Cardone Friction Choice Brake Caliper-Rear
Part No. 18-4345 Right
72.99
Part No. 18-4346 Left
72.99
Front calipers
Cardone Friction Choice Brake Caliper-Front
Part No. 18-4072 Left
10.99
Part No. 18-4071 Right
10.99
What wheel bearings do I need for the front and rear as well and new seals? Thinking about going with earls stainless brake lines but where would I find the hard lines to replace as well? Any help on any other parts i might need would greatly be appreciated.
Brake Rotors
Part No. YH141233
29.99
Part No. YH141473
33.99
Brake Pads
Part No. GMKD 154
37.99
Part No. CNAD 154
39.99
Part No. 50-1250
156.29
Rear Calipers
72.99
72.99
Front calipers
10.99
10.99
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Brake parts
https://www.thirdgen.org/forums/tran...ing-axles.html
Hard lines can be had from such sources as http://www.finelinesinc.com/
http://www.classictube.com/
http://www.inlinetube.com/
JamesC
Re: Brake parts
Thanks for the info on the brake lines and the bearings. Don't think I will be replacing the rear bearings. I forgot that they are internal and not on the rotors like the front rotors. I did find some parts that I originally bought for an 84 trans am and all part number match for my 89 formula so that saves me some money on parts.
Now for the front bearings and seals. What I have for seals the part numbers are s-8871 and the bearings are s-a6. I believe they are the inner bearings. Now does this look like the right part numbers for the outer wheel bearing
National Taper Bearing Set
Part No. A-34
Warranty: 1 YEAR REPLACEMENT IF DEFECTIVE
Outer; Exc. Performance Pkg
Please someone chime in on these so I can start getting the rest of my brake parts to start on this project. Thanks for all the help.
Part No. A-34
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
