Prop Valve mod make it worse?
Old Apr 16, 2010 | 12:15 AM
Americanmouse's Avatar
Car: 1988 IROC-Z28
Engine: L98(383tpi) modified
Transmission: 700R4 rebuilt
Axle/Gears: 3:73 10bolt rebuilt
My brakes were always bad, most likely due to my cam. I even have a brake booster and C4 up grade on the fronts. Which did a just ok improvement. But over the winter I did the Prop Valve mod up grade for the rears and now my brakes have little pedal. I also bought a Hurst line lock from one of the members awhile ago and hooked that up too. So I disconnected that but still hardly any pedal. I've been bleeding the brakes for 3-4 days straight, and still nothing. I'm about ready to take in to a shop and have them try and fix the problem, or at least tell me what the problem is so I can fix it. But any ways can removing the guts from the Prop Valve and then plugging it up with a Threaded plug cause you to loose pedal? I've already destroyed enough paint, so before I make more of a mess I would like to hear what other people have experienced.
Old Apr 16, 2010 | 12:16 AM
Car: 1988 IROC-Z28
Re: Prop Valve mod make it worse?
Oh! the brake booster is a additional add on by Crane Cams.
Old Apr 16, 2010 | 04:05 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
check for vacume leaks feeding the booster, thats where my issues came from.
Did you remove the internal piston in the prop valve?
you probably didnt, since you didnt mention leaking fluid through the brake light switch on top.
did you properly bench bleed the master?
does the pedal drop to the floor, or travel about an inch then get really hard?
Old Apr 17, 2010 | 08:24 AM
Car: 1988 IROC-Z28
I bought a Master Cylinder bleeder kit from the auto parts store. Rebleed the Master and the rest of the system and now I have good brakes, even better than before.
Old Apr 17, 2010 | 11:52 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
glad it worked out for you!
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
69 Six Pack
Oct 5, 2015 07:51 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
lakeffect2
Aug 23, 2015 08:44 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
