Master Cylinder brand
Old Apr 21, 2010 | 10:28 AM
joshwilson3's Avatar
Looks like I will be replacing the master cylinder at some point. I've noticed for a while that there would get a black film inside the reservoir with small black sediment pieces. Looks like that means the seals are going.
I'm getting a $50 off coupon from Advance. So, I was thinking of going with a $50 NEW Cardone master cylinder that includes the reservoir. Anyone use this brand for a new master cylinder?
Autozone has a NEW MC by Fenco for $60. And I think Napa is $100.
Old Apr 25, 2010 | 06:55 PM
Re: Master Cylinder brand
Is no one replacing master cylinders here?
I think mine needs replaced. I just cleaned out the reservoir and flushed most of the brake fluid myself. Then had a shop replace the front calipers.
A couple of days of driving, and the brake fluid in the reservoir is already solid black.
I know when I've cleaned out the reservoir, that there is small black particles and black film I had to clean up. I've read that is the seals breaking down.
I'm gonna start buying parts myself, that way I can use a lifetime warranty. If I have a shop replace it, then they close down. I'm screwed out of my warranty as this is the 2nd or 3rd master cylinder and I don't know where it was bought from.
Old Apr 25, 2010 | 07:09 PM
kens86's Avatar
Car: 1986 Camaro
Engine: 436" SBC
Transmission: TH350, 8" Converter
Axle/Gears: S60 with 4:11 and Locker
I'm running a strange manual master.
Old Apr 25, 2010 | 07:12 PM
That doesn't apply to me as I'm keeping my car stock with a stock type master cylinder with power brakes. Looking for recommendations on a stock type master cylinder that you can get at a local parts store. I think it is down to Advance or Autozone.
Old Apr 25, 2010 | 07:23 PM
86 LT1's Avatar
I Used auto zone Fenco reman for 24.99 works great for 24.99
Old Apr 25, 2010 | 07:32 PM
Thanks. I'm probably gonna spend the $50 or so and get a new one. As this is the 2nd or 3rd one in 10 years. I remember I had gotten a rebuild from Autozone 5 years ago I believe, and it was leaking when the guy was bench bleeding it. I don't recall what they put on instead, but I believe it is the one that is on there now.
I'm thinking the Fenco might be better as I believe Cardone is China. I'll have to keep searching under those brands. But at least what ever I get, it will have a life time warranty. And I'll have my receipt so I won't have to buy another one.
Old Apr 25, 2010 | 07:36 PM
86 LT1's Avatar
no there cheap and easy to replace unlike some
Old Apr 25, 2010 | 08:37 PM
Whatever I get Fenco or Cardone, it is gonna be new. With rebuild, it is a crapshoot. Also the new ones come with a new reservoir already mounted, which I like.
Also, you have to watch out on rebuilds and new ones as some are cast iron. You want aluminum. I know the rebuild Cardone is cast iron. But their new one is aluminum. I'm not sure on Fenco, but they look aluminum.
Old Apr 25, 2010 | 08:49 PM
86 LT1's Avatar
the 24.99 was aluminum with reservoir
Old Apr 25, 2010 | 09:03 PM
Hmm. They may have changed things as the price is higher, and it says it doesn't include the reservoir. But it could be a misprint.
Anyways, I'm gonna go new. I may just go with the Cardone since it is $50 new compared to the Fenco which is $60 new.
db057
Apr 28, 2019 07:45 AM
blackandblue02
Sep 10, 2015 08:19 PM
Street Lethal
Sep 7, 2015 01:09 PM
SG91camaro
Sep 5, 2015 10:27 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
