Lt1 rear end and e-brake
Old May 2, 2010 | 02:35 PM
Transamthunder's Avatar
Using parts from my 95 Trans Am to build on my 85 TA, and I would like to use my 4th gen rear end along with the disc brakes. The e-brake hasnt worked though for a while since I took the rear calipers off to clean things up. Not sure if maybe I got things backwards or what but springs are on. I looked at another car as reference and is there a wrong way to get things placed on there? You can apply the hand brake in the car, but it isnt applying the rear parking brake. With me retaining my 5 speed I need the parking brake when parking in my driveway. Also going to replace both calipers they just dont seem to have the appling force for braking anymore. Also you do need to buy a proportioning vlave if your going from drums to discs if I remember right. Going with this rear end so I can use the Grand sport rims with some 315/40/17s. I wanna turn and burn through the twisties too.
Old May 2, 2010 | 03:24 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Lt1 rear end and e-brake
The last half of the following should provide some insight into what the swap requires:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
