C4 HD Questions
Old May 4, 2010 | 11:49 AM
actarnoff's Avatar
Car: 1991 RS/B4C clone
Engine: 355 TPI
Transmission: Probuilt Street/Strip 700r4
Axle/Gears: 7.625 axle with 3.23 gears/TrueTrac
C4 HD Questions
I was going to upgrade to LS1s, but the having to modify the steering stops turned me off. Do the stops need to be modified with either 1LEs or C4HDs?
Old May 4, 2010 | 06:39 PM
actarnoff's Avatar
Engine: 355 TPI
Re: C4 HD Questions
No one runs these brakes?
Old May 4, 2010 | 08:09 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Re: C4 HD Questions
C4s and LS1 require you to remove the stop, C5s, 1LEs, and Wilwoods can be installed without addressing it. If you look at the back side of the spindle, the A arm bracket doesn't really hit it anyway, it strikes the spindle higher up on the lower spindle "ear" so it can be removed without worry. Yes, I run these brakes.
Ed
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
