DISC BRAKES , PROP. VALVE ???
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
well my question concerns a swap . a rear disc brake entire rearend swap from a 91 Z28 into a rearend drum brake car . i know about the lines etc. , with a swap . my question is the master cylinder the same ? is the prop. valve the only difference ? thanks for help , come on JamesC . , i know you know . thanks , yes JamesC i am still kicking . ( not as high , not as hard , but still kicking ) thanks to all & good luck .
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: DISC BRAKES , PROP. VALVE ???
The drum master is good. Grab the combination valve from the 91 or purchase one from Ed Miller at http://www.flynbye.com/catalog/i172.html You'll also need the 2nd design parking brake cables if you can't grab them from the donor car.
JamesC
thanks , i have the donor car in my back yard . so now i'm sure what to pull from it . thanks again .
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
