brake fluid
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Molasses In The Brake Lines
Contaminated fluid can cause a delay, but not a total failure to hold.
Your problem is most likely a bad booster.
Happy Racing!
How bout those too scared to drive without headlights in the daytime
and the ones that need headlights for a little rain
Happy Racing!
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Molasses In The Brake Lines
When's the last time the rubber lines were replaced at each wheel?
It's amazing how much of a difference new rubber lines can make - they stretch with age, and thus the fluid pressure expands the rubber lines instead of all the pressure going to the caliper. If you haven't ever replaced them, I highly recommend it - it's a PITA since you have to bleed the system, but it's a cheap fix.
Car: 87 formula
Transmission: 700
Axle/Gears: 12 bolt strange 3.73
i have been trying to talk my self out of changing the booster because i have been saying that it is that since day one. well i guess it is time to change it.
i don't have rubber lines. i changed them to the SS braided ones. thanks for the info.
dbrochard
Oct 3, 2015 12:43 PM
