is it possible
Old Sep 29, 2010 | 01:07 PM
vettsfan's Avatar
From: Home is La Joya Texas- right now Qatar Sand Box
Car: 91 Formula, 91 RS/SS, & 95 Cobra
Engine: TPI 305, LS1, & 5.0
Transmission: 700r4, 4l60e, & 4spd auto
Axle/Gears: 3.73, 3.73, & 3.73
is it possible
is it possible to change our drum breaks to disk breaks with out chnaging the rear end?
Old Sep 29, 2010 | 01:14 PM
RS Reaper's Avatar
Car: 90 Camaro RS
Engine: V6 3.1 MFI
Transmission: 4 Speed Auto 700R4
Re: is it possible
Yes, It is pretty easy if you got the money and the time.
http://www.flynbye.com/ has the conversion plates
Ed miller is the guy that runs the site, he is on this forum as edmiller88
http://www.flynbye.com/catalog/i30.html
Old Sep 29, 2010 | 06:42 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: is it possible
or look in the tech section on the home page, there is an article about swapping 4th gen rear dics to a drum axle. I did it years back and it was pretty easy, you have to take the axles out to do, but it just involves cutting the axle flange a little to fit the backing plate, drilling a couple holes and its all bolts up. and it can be done for under 200 bux.
Old Sep 29, 2010 | 08:44 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: is it possible
There's a section in the link below that should shed some light:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
