Caliper Locked Up?
Car: 1986 IROC-Z
Engine: 305 TPI - 350 in the works!
Caliper Locked Up?
The trans. shop said my DS caliper locked up. At first I thought they were BS-ing cause it was fine when they towed it there, but I guess it decided to lock up in transit. I did a search and have concluded that the brake hose is to blame? We got it roll-able by just draining some fluid and closing the piston. Obviously, we aren't driving it right now. My question is, do I just replace the rubber hose that goes into the flex line? Or replace the whole thing up to the master? Or could it be something else?
Thank you.
Thank you.
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: Caliper Locked Up?
Which portion of the brake line do you suspect is bad? The rubber line from the brake caliper to the hard line? You really shouldnt need to replace the hard lines unless there's some circumstance that caused them to be be fouled.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Generally speaking, the problem is general the rubber line.
JamesC
JamesC
the_hamturdler
Sep 30, 2015 12:50 PM
Damon
Sep 26, 2015 04:29 PM
Dragonsys
Sep 25, 2015 03:51 PM
