LS1 VS 1LE
Old Jan 4, 2011 | 06:08 PM
3rdgenred's Avatar
Car: 6.7 Powerstroke
LS1 VS 1LE
Whats the major difference between front LS1 and 1LE brakes? Is it worth spending the extra money on the 1LE or just getting the complete LS1 setups off ebay for 100 bucks (plus 90$ shipping!!! WTF!?!!?) Trying to figure out whats a better path to do. Any suggestions?
Old Jan 4, 2011 | 06:21 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: LS1 VS 1LE
Front and/or rear?
Most members will probably recommend the LS1's because they're perhaps cheaper and parts may be more readily accessible (though I've never experienced any difficulty in finding them). The LS1's clearly have a better parking brake set-up. Personally, if I weren't swapping all over again, I'd probably go LS1.
JamesC
Old Jan 4, 2011 | 06:23 PM
3rdgenred's Avatar
Re: LS1 VS 1LE
Fronts for right now. Maybe rears later. But okay cool thanks man.
Old Jan 4, 2011 | 06:37 PM
JamesC's Avatar
Re: LS1 VS 1LE
BTW, if you have a 9-bolt, the LS1's won't fit the housing ends. If you have PBR's on the rear currently, 1LE fronts would match nicely.
JamesC
Old Jan 4, 2011 | 06:45 PM
3rdgenred's Avatar
Re: LS1 VS 1LE
Ohh, so only the Front LS1's would work if im running a 9 Bolt BW in the rear? And i do have disk on all four corners, so would it be better to just run 1LE on all four or LS1 fronts and 1LE rears? But isnt most of your stopping force in the front anyway, so would i really need to upgrade the rear or could i just leave the stock rears?
Old Jan 4, 2011 | 08:28 PM
JamesC's Avatar
Re: LS1 VS 1LE
Yes.
I like the matching set, 1LE's all around for me. I'd leave the rears.
JamesC
Old Jan 4, 2011 | 09:06 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: LS1 VS 1LE
if you buy the calipers and such off ebay, you still have to use custom hubs and modify you spindles to use the ls1 brakes, you will also need a bracket to mount the caliper too similar to the 1le setup. they will not work straight off a 4th gen.
the rear ls1 brakes are great.
I have the 1le's on my 92 and they work very well, and the price was right at the time.
Old Jan 4, 2011 | 09:08 PM
3rdgenred's Avatar
Re: LS1 VS 1LE
Okay maybe thats what I'll do then. I'll run the LS1 in the front and leave the rears stock.
loud91rs
Oct 5, 2015 10:05 PM
dusterbd
Sep 29, 2015 08:40 AM
