Could use help getting LS1/C5 brake project back on the road
Old Jan 9, 2011 | 06:12 PM
zracTA's Avatar
I have sourced most of these parts years ago, finally got the calipers and now I have a pile of parts and a question
I'd greatly appreciate it those of you that know could chime in
I bought LS1 calipers + carriers off ebay , but I thought I had c5 brake brackets, how come things are lining up for me?
Did I buy "LS1" brackets years ago and not C5?
note: I am unsure whether I decided (years ago) to build LS1 brakes or C5 brakes, I Realize they are almost the same but I thought calipers were different, the rotor size is slightly larget with C5 and therefore caliper brackets differ.
I've searched a bit, but is there a definitive step by step write up somewhere? I know I have to cut the ears off, drill/tap holes but having details would be very helpful.
Old Jan 9, 2011 | 06:15 PM
zracTA's Avatar
Re: Could use help getting LS1/C5 brake project back on the road
I may have answered my guide question myself after some more searching :
http://www.lukeskaff.com/car/brakes/spindlemod.html
http://82lt1.cz28.com/brakes/page2.html
Old Jan 9, 2011 | 06:58 PM
frankinmaro's Avatar
Car: 87 Frankinmaro
Engine: ZZ4 short block 67 327 462 castings
Transmission: TH350-c out of Y body
Axle/Gears: 97 4th gen Torsen 3.23
I think that the only diff is in the casting process for the calipers one is gravity cast,one is pressure cast, but I might be wrong.check out ed millers http://www.flynbye.com great source for 3rd gen brake upgrades
Old Jan 9, 2011 | 07:24 PM
zracTA's Avatar
any idea of that bracket is a C5 bracket? just to confirm what I have.
I think I have brand new C5 rotors too so I'll double check that part number and I guess if the caliper carriers are the same then I'm good to go.
I believe you're right about the calipers, the C5 ones have ribs along entire top surface , the LS1 only in the back.
Old Jan 9, 2011 | 09:25 PM
bm87ta's Avatar
Car: 87 TA
Engine: 305 tpi
Transmission: auto
that is a c5 bracket, as you found lukeskaff has a great write up
jhawkeye
May 25, 2022 06:33 PM
Vintageracer
Jan 10, 2020 05:33 PM
Fast355
Dec 2, 2016 06:33 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
