98+ brakes on a 95 rear?
Old Mar 13, 2011 | 03:37 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
I recently got a nice rear end (LG Motorports stud girdle on it, haven't looked inside to see if the posi is upgraded or not) out of a 95 Firehawk. But the brakes are basically the same as the 91/92brakes, just on a wider axle, right?
Would would it take to put LS1 brakes on the 95 rear end? Just the mounting brackets are different? (besides the obvious bigger rotor) Calipers any different?
Or should I just sell it & pick up a 98+ rear end?
Old Mar 14, 2011 | 08:45 PM
Car: GTA
Re: 98+ brakes on a 95 rear?
Well....I did find a mounting plate that would put the '95 Firehawk/LT1 brakes onto the '87 9-bolt I have, so I could upgrade the 9-bolt brakes with the 95 brakes, but that leaves the 10 bolt empty, no brakes.
http://www.flynbye.com/catalog/i31.html
Would the 98+ brakes simply bolt on, since they are both 10-bolt axles?
Old Mar 15, 2011 | 12:37 AM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
I was going to do similar with the 93 Trans Am disc rear I have on my 89 Camaro. I had a set of backing plates and rotors from a 93-97 rear, the backing plates bolt right up to it. The rotors were too far gone to turn, and I found a nice deal on LS1 brakes (98+) which I did install. Those bolt right up to the 10 bolt just fine.
Vintageracer
Jan 10, 2020 05:33 PM
Eric-86sc
Apr 3, 2016 03:52 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
kyleb24
Aug 15, 2015 08:24 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
