Front Brakes Locking Up
Old Mar 23, 2011 | 07:21 AM
jimidude87's Avatar
So I bought a 1990 rs last weekend and the guy i bought it from said that he put new brakes on the front before he parked it to sell. It sat for 2 years after he put them on. I drove it home about 30 miles and it was fine. The first time i drove it after that though i hit the brakes (not hard) and the front passenger side locked up. I called the guy and he said that it probably wasnt greased enough and he came up and greased the calipers with a spray white lithium grease. They unlocked and i got it home fine and then the next day i drove it and the same thing again. Any ideas on what is causing this? Could it be bad calipers or lines? I dont know much about brake work so any help would be appreciated. Thanks guys.
Old Mar 23, 2011 | 07:58 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Front Brakes Locking Up
a common problem with older vechicles . the brake flex/rubber lines fail internally . they then act like a check valve . replace both , & bleed you should be fine . the lines are keyed lt. & rt. to the mounting brackets . make sure you install the correct one on the proper side . good luck .
Old Mar 23, 2011 | 08:16 AM
jimidude87's Avatar
Thanks, do you think i should go ahead and replace the calipers to? They were like 10 dollars for a remanufactered one at autozone
Old Mar 23, 2011 | 06:43 PM
UNCLE TOM's Avatar
i doubt the calipers are bad . the hoses are the problem 99% of the time . good luck .
Old Mar 23, 2011 | 07:29 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
it wont hurt
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
