Simple brake question
Old Jun 14, 2011 | 02:58 PM
robguitargod1's Avatar
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
With LS1 disks all around, what master and prop valve should be used? I've searched and some say 1LE prop valve with stock master, but I'd just like to see what everyone else says. Thanks.
Old Jun 14, 2011 | 04:55 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Simple brake question
of the available prop valves, the 1le valve would be best.
using a adjustable valve would probably be a little better than that and will allow you to tune the brakes for maximum performance and proper bias based on the car and driving style.
Old Jun 16, 2011 | 11:48 AM
Car: '91 LS6/T56/9"
Engine: LS6
Ok so after reading the adjustable proportioning valve install tech article here I've decided that's the way to go. However, every adjustable prop valve I find has 1/8th" inlet and outlets yet our rear lines are 1/4" (I checked this morning). So how do I install it when the lines are too big? Cutting/flaring is no big deal, but I can't see how this works.
Here's the tech article:
https://www.thirdgen.org/propvalve
Here's an adjusting prop valve:
http://www.summitracing.com/parts/SUM-G3905/
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
gta90
Sep 15, 2015 04:00 PM
redmaroz
Aug 16, 2015 11:40 PM
