Brake Problem after rear swap
Old Jul 10, 2011 | 08:27 PM
Method_z28's Avatar
Car: 92 camaro z28
I have a 92 Z and it came with a limited slip drum rear. I converted to a limited slip disk rear out of a 88 iroc. Well I also swapped over the porportioning valve.
Problem
The rears arent working at all. When I bleed them fluid comes out but not really alot. I have replaced all the lines and calipers. They did the same thing with the stock porportioning valve aswell. Any advice would be appreciated.
Old Jul 10, 2011 | 08:35 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Brake Problem after rear swap
did you replace the flex hoses, even the one from the chassis to the flex line before the axle?
does the "new" rear have the crappy iron calipers or the aluminum pbr ones?
Old Jul 10, 2011 | 08:39 PM
Method_z28's Avatar
Car: 92 camaro z28
No. I just swapped the porp valve and the lines from the t spillter to each caliper. Iron calipers.
Old Jul 10, 2011 | 08:47 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
its possible that you have collapsing flex lines, but more likely its because the factory iron calipers rarely work at all, they are terrible. There are a few threads about a different spring to swap into the prop to allow more pressure to the rear calipers, should still be on the top page in "Brakes" or one back. That may help, check it out.
here
https://www.thirdgen.org/forums/brak...e-upgrade.html
Old Jul 11, 2011 | 06:19 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The following thread is interesting enough in itself, but also contains a link to the 'recall' fix for the Delco-Moraine calipers.
https://www.thirdgen.org/forums/brak...ke-adjust.html
JamesC
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
kyleb24
Aug 15, 2015 08:24 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
