LS1 confused
Car: 87 GTA, 99 VFR800
Engine: 5.7 TPI wrong heads , 781cc
Axle/Gears: 3.08, msg me if u hav 3.42 4 sale
LS1 confused
I Don t quite understand the LS1 upgrade idea yet. How will i find the LS1 parts?
DO I get a donor from the salvage yards?
I just need some help understanding where I start the research.
1989 TA stock
1989 TA stock
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: LS1 confused
http://www.flynbye.com/catalog/i47.html
If not, the above will at least provide a pic and info of parts you'll need from the bone yard. You'll have to have rotors cut down for hubs. A search should provide a ton of info.
JamesC
Car: check
Engine: check
Transmission: check
Re: LS1 confused
More info on brake upgrades can be found here:
http://www.lukeskaff.com/car/brakes/...e_options.html
RBob.
Car: 1991 Z-28/ '94 Impala SS
Engine: 355 TPI/ 350 LT-1
Transmission: T-56 in both
Axle/Gears: 3.73 / 4.56
Re: LS1 confused
"LS1 brakes" is really a misnomer. As LS1 engines came in several vehicles. The "LS1 brakes" refers to the 1998 through 2002 Camaro & Firebird brakes. They are a decent set up.
RBob.
RBob.
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
Re: LS1 confused
Ebay man. I got EVERYTHING front and rear for $350 shipped. Didn't have to turn the rotors, and the rear even had almost new brake pads!
