Right rear brake hose??????
Old Aug 25, 2011 | 04:20 PM
phlipdawg's Avatar
I'm having a problem finding the correct right rear brake hose for my car. I have a 89 Transam GTA 4 wheel disc brake car. I replaced the "center" hose on the rear. The left caliper has a hard brake line (no hose) and the right side has a hose going into the caliper. Every hose I've seen at the auto parts store is the wrong hose. Anyone know which hose I need?
Old Aug 25, 2011 | 05:25 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Right rear brake hose??????
An 89 with rear discs should have the so-called performance/1LE rotors and calipers with flex lines to both sides. Sounds as if the rear is from an 82-88 car.
JamesC
Old Aug 25, 2011 | 07:32 PM
phlipdawg's Avatar
thanks for the reply, It is indeed from a 88 or older car. was able to find the correct hose. It would probably explain why my speedometer is off also. I'll try and figure out my gear ratio this weekend.
Old Aug 26, 2011 | 10:26 AM
LarryL's Avatar
Car: 84 TA,69 camaro,81 vet 92 vet
Engine: 400
Axle/Gears: 3:73
I used a front hose on both sides. My steel lines were bad and could not get back hose. I used the premade steel lines bent them to match old one. I also put fuel hose over brake hose to protect it from rubbing on rear. Mine is 84 disc rear.
This really made my live simple when I went to C5 brakes. I just connected the C5 hose to steel lines and to caliper.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
kyleb24
Aug 15, 2015 08:24 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
